Leave that point gap at .013 where the factory put it. Increasing it will only cause your coil to burn up faster. If you want a hotter spark, buy a hotter coil, and/or convert it to 12 volts.
Check your high idle screw inside the gov. It has probably vibrated loose and moved on you. Set low idle first, then high idle. Check your serial number tag for the high idle setting. While you're in there, spray everything inside the gov with carb cleaner and make sure it all moves like it is supposed to, and don't forget to check for broken parts, like the spring, which may need replacing anyway. Then change your oil and filter. If this doesn't do it, the gov may not be adjusted to the carb correctly. If you need to know how to do this, let me know.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
