Posted by P and R Pete on March 12, 2009 at 07:40:32 from (173.86.4.206):
In Reply to: Clutch Adjusting... posted by eric skokan on March 11, 2009 at 22:02:49:
Eric, here's the premise as Scotty described, and indeed my fork was bent forward about this much on my SA.
Where do you hear that "grinding noise" coming from?
That fork is supposed to be straight up and down. In a worse-case scenario, bent forward even more, that bottom front tip of the 'handle' of the fork, that part that moves forward when the pedal is depressed, could be hitting the spinning pressure plate assembly, causing the 'grinding' noise in the bell housing.
AND thus necessarily pulling even MORE of the clutch rod forward to make the adjustment.
If you got someone on the tractor to push the clutch pedal down, (motor off) and THEN you stuck your hand in the hand-hole, (so your fingers don't get mashed), you may be able to feel if the bottom of the fork is hitting the pressure plate.
That fork is not the most solid piece of metal, and I could see how it would get bent if, once the throwout bearing was bottomed on the clutch fingers, a previous owner with a heavy foot had tried to press it down even harder.
This post was edited by P and R Pete at 07:49:47 03/12/09.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
