Posted by Zachary Hoyt on June 05, 2010 at 13:36:13 from (184.8.250.192):
In Reply to: hydr. posted by Michael/Cindy on June 05, 2010 at 13:02:38:
If you have a belly pump set up with the push/pull rod all you have to do is put the rod in the neutral position and it will be fine so long as there is oil in the pump. If you have auxiliary valves on your hydraulics the easiest thing might be to remove the belly pump driveshaft on the back of the pump. It is about 4" long as I recall and has a collar on each end. Pull out the cotter pins and slide the collars back on the shaft and it will slip right out. Then you don't have to worry about it. If you have something other than a belly pump someone else'll have to tell you what to do. Zach
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
