Posted by Janicholson on June 03, 2010 at 17:33:34 from (64.61.211.207):
In Reply to: Re: Farmall A Wiring posted by Afarmall on June 03, 2010 at 15:44:52:
I now have enough information to fix the problem! The 4 position switch is not correct for a voltage regulator system. (by the way some Cutout relays had the same box as a VR, and 3 wires as well!) If yours is a new VR, here is the scoop:: Do not use the terminal labeled Voltage regulator. connect the F terminal of the VR to the F terminal of the Generator directly. The F terminal is the smaller of the two on the gen. Connect the Bat lead of the VR to the amp gauge (opposite the lead that goes to the starting switch.) Connect the Arm, or GEN terminal of the VR to the Arm terminal of the Gen. (bigger gen terminal)
The Remaining terminals are just fine. Power in to the same side of the Amp gauge as the Bat wire from the VR.
Tail light, and headlight. are good to go.
The switch will have 2 OFF positions far CCW, and the next position CW from there. D and B should be fine for the lights. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
