Posted by IH fan on May 31, 2010 at 17:28:37 from (70.244.99.105):
In Reply to: internatinal 240 posted by hawkeyeden on May 31, 2010 at 11:58:55:
Without checking, that's about what I paid for mine two years ago. It needed the steering box repaired because the arm was loose and wore out the shaft out the bottom of the box. Somewhere in it's life, someone had replaced the steering arm with one from (as far as I can tell) a 404, and the gear had been turned 180 degrees with a new keyway milled in the shaft. It would hit the hole in the casting when turned end to end because the arm did not have enough offset in it. I bought both the gear/shaft/arm and worm gear assemblies and now it works fine. If it has PS and uses the tractor pump, the loader will be slow and I think that's the reason mine has the added pump and valves. The loader reservoir is in the frame of the loader. It appears at one time the tractor system had been used for the loader. with the added pump and valves, the loader is fast and will lift anything I have tried so far. I try not to overdo it because of the reputation of the weak front end. Also on mine, the power steering takes enough flow from the pump that when idled down the 3 point won't work. Get the engine a little above an idle and it works.
Mine had a fresh paint job on it when I got it, so it looks pretty good for a 1958 model tractor, except the side panels are missing as they seem to be on most of these. It does start and run good. One big drawback to these it that for a late '50s tractor you'd think it would have an independent PTO, but it doesn't. You will miss that when mowing.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
