Re: farmall m live hydraulic hook up
Posted by mkirsch on May 30, 2010 at 18:34:34 from (67.253.216.24):
In Reply to: farmall m live hydraulic hook up posted by a bartholomew on May 29, 2010 at 20:45:09:
Regardless of which live pump you have, it plumbs basically the same way.
You can use the belly pump as a reservoir only. None of the belly pump plumbing or valving is used.
You hook a hose from the drain on the bottom of the belly pump to the intake on the pump.
You hook a hose from the output on the pump to the in port on an open-center two-way valve.
You run a hose from the out port on the two-way valve to the fill pipe on the top of the belly pump.
That's pretty much it. Make sure the two-way valve has an adjustable relief valve built-in.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
