Posted by rustyfarmall on May 26, 2010 at 07:19:57 from (209.152.78.140):
In Reply to: high ideling H posted by Farmallb on May 26, 2010 at 06:02:58:
Farmallb said: (quoted from post at 06:02:58 05/26/10) I backed off the screw underneith the govenor tube, But didnt make a difference. Will check choke plate for looseness. It runs perfectly. Pulled a IHC wing disc without the wings, but with RR ties in the weight brakets, no problem
I think you need to completely remove the carburetor. Inspect the ears on the throttle shaft, and inspect the little tang on the shaft coming from the governor, and while you are looking, make sure the throttle plate is still attached securely to the throttle shaft. If all of those things check out, then it is time to remove the cover from the governor and have a look inside.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
