Re: super c clutch redo
Posted by Janicholson on May 22, 2010 at 07:14:50 from (64.61.211.204):
In Reply to: super c clutch redo posted by jonathan mirgon on May 22, 2010 at 04:20:49:
Pressure plates are adjusted out of the box!
Unless you have good measuring tools, and the solid evidence that things are wrong, leave the screws alone. Your new friction disc could be put in backwards, it must have the cushion springs in the middle facing away from the flywheel. If they are forward, the springs and hub interfere with the bolts on the FW. and the clutch fingers are too far depressed and it will not adjust. A bent friction disk (from even modest force being used to put the tractor back together can also cause drag.
A improper Throwout bearing is also a suspect.
If the fingers are depressed more than about flat to the disk, I suspect the plate is in backwards.
Best of luck. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
