I believe the system should hold when in the mid position of the lever. If it does not, and there are no leaks to the outside, and the cylinder on the equipment is not bypassing internally, the internal valve may be worn. Is it a two way (two hose) connection to the haybine? If so, raise it, block it up with a floor jack, and disconnect the hydraulics. Let it down and see if it lowers on its own. If so it is the cylinder. Adjustment of the rod might be needed, but is usually not the issue. Pull the rod out just a smidge to see if the stop is out of place. Not to the point that it puts load on the pump, just enough to see if it is getting into the lower position of the rod. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
