Posted by Chas Weller on May 17, 2010 at 17:10:57 from (71.245.59.83):
Originally posted 5/6 (thanks for advice) tractor stalled after working about 15 to 20 minutes. Will now not start, tries to run but fires out exhaust pipe? Have had tractor about 10 months normally easy to start as long as you catch it when it first fires; otherwise seems to flood? Replaced plugs, points, condenser, cap and rotor all appeared old. Spark at all four plugs. Please help with suggestions? since then compression is (1)70,(2)80,(3)85,(4)90 - not great but still should run? will not start fires out both exhaust and intake - Have spark, Air, Fuel. I think that indeed the cam/timing gears have broken or slipped? I have removed the valve cover and all valves are opening and closing - how is this possible if the timing gears are broken, since there is no chain is it possible for the gears to jump? Not break but jump teeth?
Many thanks to all for discussion, help, advice and pictures.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
