In a ball bearing there should be ZERO axial movement between inner and outer race.... Should be very little to no radial movement either... If there is the bearings are junk...
As I've said before, in the case of my Super A the bearing on the sector shaft was bad as stated in the first paragraph. When you turned the wheel the sector gear and shaft would raise before turning.. You could see it plain as day. The tie-rods and pitman arm would move vertically before beginning to turn.
There isn't much that can go kaput in there but what does cause a lot of play...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
