Lets assume the battery is New, and charged. Use a volt meter to check if there is voltage at the posts of the battery (not the wire terminals, the actual posts on the battery) if volts, now check volts from Pos terminal to negative cable end. If no volts, the negative cable end (at the battery) is not clean enough to conduct electricity from the post. If volts, check from the Neg post to the positive cable end. If no volts the pos cable end is corroded. With voltage in the wires leading from the battery, we now check by using a different method. Turn the lights on. (Assumes no lights come on) At the ground strap to frame/engine, test voltage from wire end to chassis. (tests the ground) If voltage is found clean that terminal. (no volts should be found) Now test from ground to the connector at the solenoid where the other battery lead is connected. Voltage Good no voltage, bad wire. Now there should be a second wire connectred to that post. Make sure it has power, if not clean the stud and terminals on it. Follow that wire making sure there is voltage at each connection. Use the diagram, and follow the power to the key, lights , and charging system. You will find it. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
