Posted by Wardner on May 07, 2010 at 20:27:40 from (207.69.137.15):
In Reply to: 460 Farmall hydraulics posted by Monroe Stephenson on May 07, 2010 at 14:11:45:
It's easy enough to follow the hoses back to the valves. On a 660, and probably the same is true on a 460, the valves are easy to see and access. The same can't be said for a 400 that uses the same valves.
I think you will find that the left hand valve goes to the rear remotes. If there are three valves, the middle should go to left remotes and the right valve should go to the right remotes.
Some valves don't have single or double selectors. If yours do, clockwise, while looking at end of valve, is single. Counter-clockwise is double. "D" and "S" are stamped or cast into the cast iron end plate of valve.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
