Interesting Starter problem on SA
Posted by marvin on May 28, 2000 at 15:46:44 from (209.180.201.189):
I have a 47 Super A that has an interesting starter problem. If I leave the ignition switch in the off position, the starter will crank the engine over without any problem. If I turn the switch on (pull it out) then the engine cranks over only about one or two revolutions and then stalls. If I have the switch off and then start cranking the engine over and pull the switch out while continuing to crank, the engine will also stall. If the tractor has been sitting for awhile then it will crank over fine most of the time with the switch on and start okay. The tractor always starts after three or four revolutions if I can get it to crank that far. Two side notes. 1) I think the cut out regulator on the generator is not working and is overcharging the battery. (Fluid in battery is boiling over.) 2) The Ammeter is not working. Just sits on zero. The tractor seems to have the original wire harness and is getting tantered. I did check the drop from the Positive side to the starter case and got about 0.9 volts, while the drop from the negative post to the starter post was 0.45 volts. I did clean up the connections on the negative side, but that did not help. It does not seem that there should be very much current draw from the distruibutor and coil that it would cause the starter to stop turning. Any thoughts on this.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
