Posted by cob_crusher on May 04, 2010 at 12:04:38 from (24.213.205.227):
changed hy filter (left side motor & hy pump). cleaned o-ring carefully on cannister, tightened clamp & bubble tested for air leaks. added hy fluid until front axle sight glass full. put hy end with 3000 psi gauge in aux remotes. showed 2000 psi. cleaned pilot system relief valve (by valve stack -- behind right shoulder) check end of relief valve for dirt & check o-ring for good seat. when i opened valve cap was an air build up. was pre-venting full pressure to lift cylinder on disk. works aok now.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
