It is not going to come off without removing the front casting. It is pressed on. It cannot be pulled with a two or three arm puller, it will break the pulley. A plate (1/2" made in a U shape to fit behind the flange will allow a good pull. Most come off with a hydraulic jack and a socket fitting down against the crank snout. The jack pulls on the U shaped plate (above with 5/8 or 3/4" ready rod and double nuts.) If it stays in the frame, a jack that pumps when horizontal is needed, or a Porta-Power. I had to put one in a 60 ton press to get it off, and it was almost 4 ton of pressure on the ram. Before reinstalling, clean everything and polish it up. Inner bore and shaft both need to be shiny. Heat the pulley to ~ 200 degrees then put it on rapidly pulling it in with the threads in the crank. Be sure there is no wear groove in the pulley where the seal rides, or put the new seal in a location that uses a different spot. Always polish the shaft roundy round not along the length to keep from wearing the seal. Put grease on the seal when putting it together to prelube it on the shiny shaft. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
