Posted by Haas on April 21, 2010 at 17:22:56 from (75.234.204.140):
In Reply to: IH 424 hydraulics posted by GARY69 on April 20, 2010 at 10:55:51:
How do you know you have low pressure if you have not measured it? If the 3 point will not pick up or is cycling, it is probably the cylinder which is internal to the hydraulic unit under the seat. If you have a manual, it should tell you where the tap is for the remote and thus you can put a pressure gauge there and measure the pressure. I used to have a 424. There is a shut off valve on the 424 system (don't recall where, but somewhere near the hydraulid unit). When you shut that valve off, it isolates the 3 point lift cylinder. If you close that valve with the lift in the up position with weight on it and the lift goes down, then you have a bad lift cylinder. You may need new seals, or a new piston and cylinder. The original seal on the piston was leather, no longer available so you'll need a new piston with seal if it has not been changed before. Parts for this are very expensive from IH. You can get parts from a Mahindra dealer that will fit and are more reasonably priced, as the Mahindras were originally copies of the 424.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
