I have a 1953 SA. I also have a 2 bottom breaking plow. Remove any plows you may have on the front of tractor. Remove the draw bar on the rear of the tractor (you must have the draw bar) and turn it around and move toward the front of the tractor beneath the brake and clutch pedals. There will be to mounting bolts on each side of the rear end housing just like where it mount in the back to pull with. On the mounts of the draw bar on each side there to 1/2" bolts that hold the draw bar tight to the mount - loosen these bolts but do not remove at this time. With the draw bar moved to the front of the tractor back the tractor up the breaking plow - on the plow there should be a bar with two links of chain attached to the plow - this bar is a hollow tube with a steel bar running through it - this bar slides in the so that you can slide the solid bar through the lift holes in the arms of the power lift - with that all hooked in place with the tractor running use the power lift to raise the plow off the ground where it's just swinging under the tractor. On the front of my plow there is 2 u-shaped clamps that hook over the draw bar for pulling power - in the center of the 2 u-shaped clamps there another hook up with holes that will slide over the draw bar and can be held in place with a pin (about 5/8" inch or larger in diameter) and the pin is held in place with spring clip. Now with all that hooked you need to remove the 2 half inch bolts from each side of the draw bar - this will allow you to tilt the front front of the plow to help it go in the ground. There should be a long flat piece of steel that goes from the front of the plow and pins to the rock shaft of the power lift to tilt the front of the breaking plow. With my plow there is another piece with a "J" hook on the bottom that fits in an eye bolt on the breaking plow - the other end of the rod hooks to the steering rod support on the tractor - this rod is used to tilt the plow with the driver in the seat. I've had my tractor for more that 40 years and I've never used it. I just use a big screw driver to turn the eyebolt and once I got it set I've never changed it. You'll have to use trial and error to adjust the chains in the rear to control the depth that the plow will run. The thing about the SA's with the power lift that if the plow starts to run too deep or shallow the adjust with the power lift. Take your time and study the plow and the parts that come with and you will figure it out - I didn't have the the internet or anyone to help - just had to look at all the pieces and figure out to make them work. I know this is a long post but I tried to make is simple. Hopes the helps - James
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
