The 361/407 engines really like to be fully warmed up before putting them under load. If you put a cool engine under full load on the dyno, most of them with the original style head gasket will leak some between the block and head. They seal up when they get to operating temperature.
A new style head gasket may cure your problem with the seepage but running in a lower gear until up to operating temperature may make it less noticeable.
When the head is off it should be checked for straightness but I would not have it surfaced unless it needed it to be trued up. Most of the later diesel engines have a spec that only allows about .010 to be removed from the head surface. That doesn't necessarily mean that it won't work if more is removed, but that is the minimum head thickness that IH published.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
