Dan G said: (quoted from post at 04:04:13 04/13/10) I have a compression tester. What should be the compression psi? I will try the "oil trick" today , hopefully.
I'm thinking anything over 80PSI will start fairly well. 100PSI is good. 125PSI is great. When you start getting down into the 60-70 range it's time for a rebuild.
How is it cranking over? If it's just barely rolling over, it may not start after sitting for so long.
Are you using the choke? Too much or not enough can cause a tractor to not start, but each tractor is different.
Are the plugs wet when you pull them after cranking for a while?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
