Posted by Cub149 on April 11, 2010 at 12:16:39 from (98.17.210.230):
In Reply to: 350U Axle Seal posted by Andy Martin on April 11, 2010 at 11:13:01:
Max(ia) said: (quoted from post at 19:13:01 04/11/10) Rear axle seal leaking. Is this a major project to replace? Also, what fluids are used in Trans. and Rear End. Thanks
If you have a T/A, you should use Hy-Tran or equivilent. If not, 80w90 gear lube is a substitute. You need to take off the wheel, then remove the center bolt from the hub. The hub is splined to the axle and needs to be pulled off. Then the four bolts on the bearing retainer where you will find the seal. Also need the O-ring type gasket to seal the splines and either gasket or silicone for the bearing retainer.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
