Dan Swanson said: (quoted from post at 04:38:36 04/07/10) is hitting the floor board when you let out off it & there is no free travel what so ever. With the low side possible out on the T/A, is that why it is hitting then? That's why I thought the clutch may not engaging completely because the pedal is hitting the floor. Dan
Dan, you said the TA is holding in direct (lever forward). That means the main engine clutch, while it definitely needs adjustment, is okay.
The clutch linkage on these hydraulic TA tractors only trips a dump valve which allows you to shift, IIRC. If the clutch linkage is so far out of adjustment that that dump valve isn't closing, the tractor won't go at all as I understand it.
It's not like the mechanical TA where the clutch and TA linkages are intertwined, and having one out of adjustment will either wear out the TA or make it impossible to shift.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
