I have a PTO housing with the identical groove in it, and it wasn't there before my father bought the mower. The Kosch pulley cut the groove all by itself. Either the pulley got a little loose, or something bent it, or somebody pushed it a little too far on to the shaft. If you check you can probably see that the edge of the pulley is polished , or even sharpened a little where it rubbed.
I don't know which pulley hub you have, but if you are going to use the mower very much, you should make sure that the pulley is as tight as possible. If it runs loose it will eventually, (in ten or twenty years), destroy the splines on the PTO shaft. Long before that it will wobble and make noise, as well as cutting th groove deeper into the housing.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
