If the injector is leaking internally and not from the external fittings there are no seals to replace to correct the problem. The surface finish between the nozzle assembly, body, and spacer all have to have a smooth enough finish that they will not leak under the nearly 4000 PSI the injectors operate.
If it is leaking antifreeze from around the injector then you will need to replace the nozzle in the head.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
