Posted by John T on April 06, 2010 at 05:13:49 from (66.244.97.31):
In Reply to: Super A 6 volt wiring posted by aquanosis on April 05, 2010 at 21:32:21:
It dont hurt if lighting and ignition wiring is a little larger then stock and if you only want to buy one roll of wire you can "get by" with 12 Gauge for lights and ignition and charging etc. 14 or even 16 could get you by for some of the lighting but like I said Id use 12 for a little overkill.
I prefer 0 better yet 00 for battery and starter and ground cables.
If I were doing it Id even consider 10 Gauge from BAT on VR or Cutout Relay up to the Ammeter and also 10 from other side of ammeter to the battery often via a wire to the starter switch. Likewise 10 from the Gennys ARM post to the VR or Cutout Relays ARM/GEN terminal. ALTHOUGH AS I MENTIONED 12 GAUGE WILL SUFFICE (if you only have one roll of wire) as typical charging currents and loads would be 20 and less amps. The stock harness may have used 14 or 16 on some lights and ignition wiring but again no harm if slightly larger wire is used.
If you use quality wire terminals and solder them then cover with heat shrink you will get a good job and connection
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
