No split required. Pull pump out if equipped. Remove clutch shaft and related parts. Photo the coupler and be patient. Loosening the clutch disk, or putting three of the clutch cover bolts (from 120 degrees apart) into holes near the levers to compress the clutch. and holding your mouth just right will allow the shaft to come out. Then pull the flange off. a puller, or using the shaft yolk as a puller against the shaft with a socket to push on (center bolt removed) will get the drive yolk off, then just pry out the old seal. Check for a groove in the yolk, and if it is easily felt, I would speedy sleeve it, or run the new seal in a different depth to provide a good seal. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
