Kevin Brooks said: (quoted from post at 12:33:37 04/05/10) Have an "51 M with partially rebuilt carb: new needle/seat cage and gasket, new float bowl gasket. Float level measured 1 5/16" per manual. Finding gas leaking out choke lever shaft after increasing engine speed control. What is likely causing the leak. Also, main fuel/air mixture screw currently set at 3 turns out. Not yet tuned for full throttle. Would leak disappear once tuned? Tractor head listed as 6336 for kerosene and carburetor has numbers matching those for kerosene. However, I only run gas.
Sounds like you did everything right, BUT, make sure the float does NOT leak, is not dragging on the sides of the fuel bowl, and make sure that new float valve seat has a good gasket under it and that it is good and snug. If the float is right, and the float valve and seat are right, there should be NO gas leaking from the choke shaft area. Also, 3 turns out on the high idle screw (bottom) is enough, no need for any further adjustment unless the engine stalls or sputters under FULL LOAD. The idle/air mixture screw (top) is set at 1 1/2 turns out, and is only to be adjusted for a smooth idle AFTER the engine is warmed up.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
