Since you know something is sticking within the clutch, maybe a lot is sticking. Makes me think Bob is on the right track. If it won't come apart following the suggestions already made, you may need to unbolt the pressure plate from the flywheel. I've never had to try it, but think you can do it through the hand hole in the bell housing. If the pressure plate is the type where 3 bolts are used to hold the springs compressed, move every other pressure plate bolt to the open holes then remove the 3 remaining bolts. If you can do that, the pressure plate and clutch disk will stay in the bell housing when you split it. Then you can get at the disk to remove it from the splined shaft.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
