Posted by Wardner on March 18, 2010 at 20:00:20 from (4.154.238.150):
In Reply to: Hydraulic question posted by Spotted Horse on March 17, 2010 at 22:58:21:
I would consider converting the transaxle into a reservoir. Replace the gear oil with Hy-Tran or equivalent. Place a strainer, check valve, and tee at the rear drain plug or a safer remote location with a suction hose. The check valve might not be necessary. It depends how good your pumps are at holding a prime.
Despite what Jim says about the PTO pump, the Prince pump will easily handle 1200 RPM. The same pump is used with 1000 RPM PTO. The mfg changes out the internal splines to suit 540 or 1000 PTO shafts. I can't think of any small hydraulic gear pump that can't run at 2000-2500.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
