The whole key is to be sure everything is supported as you take things apart.
We just did a front seal on an M by supporting the rails, loosening the front engine mount bolts, removing the bolster bolts and using a engine hoist with a chain wrapped around the top after you take the grill off.
Keep the chain on the back side of the bolster and relieve the the pressure and roll the whole thing off the front. You will have to pry on the side rails to get them loose.
You just need to loosen or remove 2 radiator hoses and the radiator support rod and the whole thing can roll out with a little patience.
Then you will need to block up and brace under the bell housing to remove the side rails and engine. There is one bolt behind the starter and a long bolt above it that is over looked besides rail bolts that you need to remove.
Take your time and be safe checking all your blocking and bracing for good support.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
