Posted by ScottyHOMEy on March 10, 2010 at 19:16:11 from (70.105.237.152):
In Reply to: Kill Switch posted by Two Banger on March 10, 2010 at 18:32:28:
Nope. With any battery powered ignition (as opposed to a magneto) a double pole switch should be wired in-line, between the battery and the ignition. One wire from battery power, the other running to the ignition.
For original style Farmall swithches, there were two types. For magneto ignitions, the switch had a single pole on the bottom. From that pole a wire ran forward to a stud on the side of teh magneto. With the switch button in thee "up" "RUN" postion the switch was open. When pushed down to the "STOP" position the switch was closed, and stopped the motor by gounding the magneto. Ground was reached through the body of the switch being mounted to the chassis.
The otherwise identical (for outside appearance, anyway) switch for battery ignitions had two poles on the bottom. In that case the switch was closed in the up postion, allowing the juice to flow from the battery (one pole of the switch) to the ignition to the pole connnected to the igntion coil. Pushing the switch down opened the connection, breaking off power to the igntion to stop the motor.
If your switch has to poles on it, one should run to a battery source, the other should run to your ignition.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
