Posted by Owen Aaland on March 09, 2010 at 15:16:53 from (198.70.47.146):
In Reply to: 560 starter end play posted by IowaHarry on March 09, 2010 at 13:18:52:
I don't recall ever seeing a spec for the armature end play in the Delco manuals. The minimum clearance for the drive gear to stop collar is .020". The stop collar should not contact the drive end housing.
The end play is controlled by spacer washers on the commutator end and between the center bearing and the armature. I have seen the commutator end washers in some rebuilt units that have been replaced with non-hardened washers which bend in use allowing excessive end play. If there is excessive wear in the commutator end frame it is sometimes possible to add a second washer to compensate for the wear. When assembled the armature must not drag from lack of end play.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
