If the loader cylinders extend all the way out you most likely have enough oil in the system. Check the oil level with the loader cylinders retracted and the hitch down. The reservoir should be filled to the bottom of the plug hole.
Most likely your problem is a dirty filter/screen. It is located in the hydraulic reservoir on the suction tube. To service it you need to drain the oil. Remove the hose coupling on the suction tube by sliding it forward enough to clear the end coming out of the reservoir. Pull the tube from the reservoir with a twisting motion.
If you should have a front crankshaft mounted pump,an option on the 2444, then the hydraulic reservoir is combined with the transmission housing.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
