Posted by Coax on February 19, 2010 at 14:46:35 from (24.113.118.113):
In Reply to: J-4 Magneto reloaded posted by usetabesteve on February 18, 2010 at 22:09:29:
Ole Shovel said: (quoted from post at 00:16:08 02/19/10) The wire to the points and the ground tab on coil have to disconnected to check it. Points wire to the center secondary output button should read no more than 12,000 ohms max secondary resistance. More than that or no reading at all it"s bad. Then from the points to the ground tab on side of the coil no more than .4 ohms max primary resistance. Again more or nothing it"s bad. You may get decent readings there and the coil could still be bad because of windings or insulation breaking down inside that only be checked on a coil tester that does a load heat firing test. Same readings also work for the IH H4 magneto.
Its as you say, I took the coil completely out and I get .4 ohms wire to ground strap... But no reading or O/L from wire to HV button...Damn. So even tho its a HV winding at the button I should still be getting some reading Right??? Crap looks like a Rebuild kit for me. Thanks for the Help.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
