Posted by Owen Aaland on February 18, 2010 at 07:45:26 from (198.70.47.146):
In Reply to: Farmall 966 posted by John Benson on February 17, 2010 at 17:45:20:
To remove the valve you need to remove the rubber cap. There is a small snap ring that holds the disk on the valve stem. The valve is removed from the underside of the cab.
If you are expecting the differential lock to completely lock both rear wheels together it's not going to happen. A good working diff lock on a 66 series at best will cause the front tire side walls to flex a little if you are turning on dry ground but the tractor will still turn. Barring excessive front end weights, an 86 series diff lock will cause the front tires to slide under the same conditions.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
