update: Cleaned up the pilot valve and everything seems ok. Just need to buy a new o-ring boss to JIC fitting cause someone used a tapered pipe thread to JIC fitting when the thread is a boss. It didn't leak but I should fix it right.
I tapped the body of the flow divider on my vise and the flow divider valve and spring popped out. Cleaned it up and looks ok.
I pried the safety relief valve out the back of the flow divider with some needle nose pliers. I could blow through through the little hole in the end. Stuck the other end in the vise and unscrewed the screw. Removed the screw and spring. The needle assembly would drop down to the holes in the middle of the valve body but wouldn't come any further. Cleaned it all good with carb spray including through the needle and seat. Installed the spring and screw and I couldn't blow through it any more.
Guess I'll buy some orings and find out on Sunday if the flow divider relief valve was the problem or not.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
