Dick Binfield said: (quoted from post at 21:40:52 02/08/10) Will 9.50 x 15 tri ribs on 6 bolt 8 in rims fit on an M with factory wide front-- tie rods in the rear? I found a good buy on these tires and rims but need information as to whether they will center up on the spindle/hub.
An M normally would not have six bolt hubs on it but there are some that fit the spindle. If you have six bolt hubs most likely the wheels will bolt unto the hub.
As far as if the wheels and tires would fit you would also need to have the right offset in the rim so that they do not rub. Measure how much clearance you currently have between the tire and spindle and then measure the offset of the rim. Compare that measurement with the wider wheels/tires and see if there is enough room to clear.
Keep in mind that the wider the tire the more the center of the tire contact will move away from the pivot point of the spindle. The farther apart those two contact points are the harder it will steer and the more stress that is placed on the spindle and bearings.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
