Brian Peppler said: (quoted from post at 14:32:07 01/28/10) I was looking at the end plate and I think it might
be strong enough for me to remove it and drill and
tap a 3/8 national pipe thread into it and then run
some hydro hoses out and run that to a couple open
center valves.
Yeah, but you can't just drill holes in the end plate.
It's an open center system, which means there can only be one path for the hydraulic fluid through the entire system.
If you drill holes, you create a second path for the fluid to flow. The fluid will always take the path of least resistance, and NONE of your hydraulics will work anymore:
You pull the lever on your spool valve, and the fluid will flow through the 3pt valve. You pull the lever on the 3pt valve, and the fluid will flow through the spool valves.
To work, fluid has to flow out of the pump, through the spool valves, into the 3pt valve, and back into the reservoir.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
