Posted by mkirsch on January 25, 2010 at 10:37:55 from (64.80.108.55):
In Reply to: Hydralics on C posted by mwilke on January 25, 2010 at 08:42:49:
The bypass block comes with instructions on how to hook it up.
Open center vs. closed center is very important.
Really, it means "open WHEN centerED," as in, the flow through the valve is open when the lever is in the center position. Hydraulic oil can flow through the valve freely.
"Closed WHEN centerED" on the other hand, the valve does not allow oil to flow through it when the lever is in the center position. If you use one of these valves on an open center system, the oil will back up and cause damage to the system.
All the old Farmalls have an open center system. The oil circulates through the pipes at low pressure all the time until a lever is pulled. When the lever is pulled, pressure builds and the hydraulic cylinder moves. Advantage here is simplicity.
A closed center system keeps the oil in a pressurized accumulator, and it only flows when the lever is pulled. Advantage here is the capability for higher pressures, and instant response. It also allows multiple valves to operate at once.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
