Posted by jimb2 on January 21, 2010 at 19:25:39 from (99.240.236.11):
In Reply to: IH 484 brake problem posted by DelmarInVA on January 20, 2010 at 20:29:03:
Hi, check for hydraulic fluid leaks from under the dash where the brake master cylinders are or for leaks along the top of the transmission housing. The brake lines run on top of transmissision housing to under the seat and then into rear end by axle housing. Check under the sheet metal on top of transmission housing. The sheet metal cover that is between the seat and the dash. If that is all good the bleeding the brakes will usually fix it. Do not pump the brakes without engine running.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
