We really need more information to give you an answer that is not just a guess. It could be either the clutch or TA that is slipping.
What was the problem that made you decide to replace the clutch?
Did you have the flywheel resurfaced so that you have a true surface with the correct step for the pressure plate? Is all the clutch linkage adjusted correctly?
Does the steering work correctly at low idle? Do you have any problems with the brakes? Those two things will give a good indication of the condition of the MCV hydraulic system. Is the linkage for the TA spool valve adjusted correctly? Is the dump valve adjusted correctly and does it work smoothly without catching any place?
If you could furnish the answers to these questions we could give you a much better answer to what is probably wrong with your tractor.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
