Posted by Pete7 on December 16, 2009 at 15:25:51 from (71.243.169.91):
Recently bought a Farmall 340 with a wide front axle (this is a row crop not the Utility) and started having trouble with the steering. You could turn the steering wheel but the tires would not turn unless the tractor was jacked up. With help from you guys I located a good used worm gear/shaft and matching wheel gear because I found the old ones were badly chipped and missing teeth. (tractor does have a loader on it) Thought that would solve the problem, right? Well, sort of, I can now turn the steering wheel and the tires turn ok, with the tractor jacked up. I don't feel any binding and it seems smooth thru the entire range, both running and not running while jacked up. But when I lower the tractor I can't turn the steering wheel. Doesn't matter if it's running or not, the steering wheel just won't turn more than a 1/4 turn or so. Shouldn't I be able to turn the steering wheel manually when the tractor isn't running? Do I have some thing binding the steering or is it a power steering issue? Pete
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
