Posted by Matt Canaday on December 13, 2009 at 22:16:43 from (74.34.118.14):
Super C Timing Setup
Hey guys, for those of you who want to time your super c dynamically, I’ve made a few notes about what I did. By the way, by dong this I found out that my timing was advanced way too much and my distributor timing weights were not working, basically they were almost froze.
First I made a pointer:
Then I downloaded a paper timing wheel, it was a jpeg file (just do a google search) and then sized it to 5 ¾” using word to match the size of the crank pulley, printed it, cut it out, and glued it to some cardboard. I then used doubled sided tape to stick it to the pulley.
Then I purchased a piston stop for about $8.00, this is essential to get accurate TDC. A very good discription of how to use a piston stop to get TDC can be found here: http://www.4secondsflat.com/TDC.html
After finding exact TDC I marked it with a file and then filed a mark for every 5 degrees before TDC, I also did one for 16 degrees because this was my target according to the manual
The Manual
I then painted the marks, below is what 16 degrees before TDC looks like.
I needed an accurate way to get 1350 rpm, I couldn't use my old school tach meter because I have also installed a pertronix electronic ignition, so I purchased a laser rpm meter for under $20. To get a more accurate rpm I stuck an old saw blade between the throttle and the serrated teeth so I could fine tune my RPM.
This little unit comes with reflective tape, I just put a piece on the pulley.
I am so glad I did this little project. Very worth it.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
