Re: 350 Utility, C175
Posted by Dellbertt on December 08, 2009 at 05:56:26 from (209.172.22.158):
In Reply to: 350 Utility, C175 posted by loafersglory on December 08, 2009 at 02:59:04:
I have never safety wired a main bearing before but I have safety wired many airplane propeller hubs. I am sure someone will tell you the correct way.
For bolts in a circle, take two pieces of safety wire long enough to complete the circle while twisted.
Twist two ends together
Put one wire thru a bolt hole.
Then wist the two tight all the way to the next bolt.
Put one wire thru the next bolt hole.
Twist tight all the way to the next bolt.
Continue until you have wired all the bolt heads together.
Twist the two loose ends tight together at the end and wrap several times around the last section you came thru.
There is a safety wire tool, similar to a pair of pliers that makes the job easy. Small vise grips will work.
Some people wire in sets of two. Either way is fine.
The idea is to keep the bolts from coming loose.
Dell
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
