Posted by mkirsch on December 08, 2009 at 05:18:26 from (64.80.108.57):
In Reply to: 1952 Cub 12V posted by Kennebunksawmill on December 08, 2009 at 02:56:18:
13.8-14.5 Volts is correct output for an alternator. It needs to charge the battery, and it can only do that by generating a higher voltage than the battery has. Electricity only flows "downhill" from a higher voltage to a lower voltage.
The coil says "External RESISTOR" for sure. Look for a white porcelain device connected in the wire running from the ignition switch to the + post on the coil. The white device is a resistor. If you find one you are okay. Otherwise you need to get one and add it in the wire between the ignition switch and coil. Most 1960's and early 1970's cars had them, so you should be able to walk up to the counter at NAPA and ask for a "ballast resistor" for an ignition coil off an old muscle car.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
