Posted by Janicholson on December 04, 2009 at 18:14:27 from (64.61.211.205):
In Reply to: Charging questions posted by J Wilbur on December 04, 2009 at 16:42:12:
By 2 wire, I assume you have connected the #2 terminal to the output post (Big terminal) this sensor wire controls the voltage output at the alternator. If it is connected well, I suspect the regulator inside the alternator to be out of spec. Typical voltage at the battery terminals at 1/2 throttle with the battery charged is 14.2 to 14.6 volts. If you operate a system much higher than 14.6 (maybe as much as 15) it will reduce the life of the battery. The exception would be short run times and cold weather. In which case the drain on the battery would compensate for high charge rates. Before replacing parts, clean all connections to the battery and ignition to Alt and bat to alt wires. Special look at the #2 terminal to output post is warranted. Good luck, JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
