Posted by Haas on November 20, 2009 at 17:49:09 from (70.222.66.125):
In Reply to: SA Mounted Plow posted by George in MD. on November 19, 2009 at 16:28:54:
It's possible to plow with these with the drawbar ridgidly attached. That is not using the bar that goes to the rockshaft to adjust the fore and aft tilt. I used one of these plows for years that way because my plow was missing the needed bar. I adjusted the drawbar to the lowest adjustment hole. Once you get started, that may make to plow go too deep, but you can adjust that with the rear touch control to keep it from going too deep. Also, be aware that it takes two or three passes to get started plowint at normal depth. The plow will go a little deeper each pass until it reaches it's normal depth. That's because the side to side tilt changes as furrow wheel runs in the deeper furrow. The side to side tilt of the plow is adjusted using eccentric bolts that are located where the hitch attaches to the plow beam.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
