That dont sound good because even if you put a genny on the bench n spin it with a motor etc with residual magentism in the iron field poles she ought to put voltage out the ARM post with respect to its frame.
Did you run the Motor Test in the Troubleshooting procedure???? Usually if it passes BOTH those checks it ought to charge. NOTE until the gennys ARM post voltage exceeds that of the battery the VR"s internal cutout relay is open so its not yet even coupled up to the battery so it could charge it.
If you temporarily jump the gennys FLD post to ground does she charge then?? If so but NOT otherwise the VR is bad or the wires bad from FLD on genny to FLD on VR. If she still dont charge when running with the gennys FLD grounded you can by pass jump around the cutout relay n see if she charges then BUTTTTTTTT if the gennys ARM post isnt higher voltage then the battery the relays not gonna close and she still cant charge the battery even if it were BY PASSED JUMPED.
To be safe Id polarize the genny once more then try the ground the FLD test and the motor test but if theres never any voltage at the ARM post shes obviously not working BUT YOU ALREADY KNEW THAT
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
