Posted by pete 23 on November 03, 2009 at 11:06:09 from (173.87.147.73):
In Reply to: farmall 350 hyd posted by robison on November 02, 2009 at 21:15:17:
With out knowing history of problem it makes it difficut to diagnose. Like previous poster said, make sure the single to double action control levers are turned properly. It is very common for them to have a bent or broken roll pin which is the stop. When this happens valve will turn too far and dump oil circuit feeding the orfice in regulator valve assembly. Also, if pin has been bent or broken previously some one may have turned valve far enough to bend the internal link to the point that even when lined up correctly on the outside it still uncovers land inside valve. Saw this happen a few times over the years.Reason that happens is because they rust tight and when they let go, bang, too far. If tractor has power steering , does it work correctly. Has it been removed. Has some one installed flow divider spool backwards. Is regulator valve piston in correctly and or pin broke off or internal spring broken. Lot of different things that have to be ruled out. Most likely, problem is in the changing from double to single action if you assembled regulator valve body correctly.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
