Posted by The tractor vet on October 30, 2009 at 04:46:48 from (75.19.126.148):
In Reply to: PTO Question posted by Doug from Wisconsin on October 29, 2009 at 19:34:14:
Well with out checking it myself here i am only guessing . Like Scot said use the Hd. clutch pac with the 7 and 9 , 7 friction disc and 9 plates . Pull it all the way down and check the teflon seals and the housing for ware . And when setting pressures make sure that the hyd. fluid is at operating temp 150 degrees or warmer . Check the engagement pressure as well as the lock up pressure and set the pressures up On the 886 set it to 245-260 and the 1206 i would set it at 240 to 270 and on the 3588 260 -280 . My 806 is set at 260 hot and cold she is bumping 290-300 the 706 is set at 250 and the 1066 is at 280 and we have her pushing well over 200 Hp, and that is the choppen tractor and i do not think that a mixer wagon is as hard to run as chopping corn in third low when the corn is two to three feet taller then the H/S wagons are . I have only had a problem with two I H PTO's and oth were on tractors running Big square balers and it was not a clutch pack problem it was from PTO shaft chatter on the turns and it would shake the clutch pack snap rings out on both tractors , one was a 1468 and the other was a 1568 . About drove me gooffy To fix that problem i ended up using a piece of key stock and tack welding it in between the ends of the snap rings .
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
